1) Does WLC support SKC + OKC on same WLAN simultaneously?
2) Documentation of 802.11r (FT) is contradictory:
Restrictions for 802.11r Fast Transition
• This feature is not supported on access points in FlexConnect mode.
• For the access points in FlexConnect mode:
• 802.11r Fast Transition is supported only in central and locally switched WLANs.
• This feature is not supported for the WLANs enabled for local authentication.
Which is the correct one?
