Slow speed between Two 3602 access points configured as autonomous bridges
CSCO10900802
I have a client that is utilizing a pair or 3602 access points configured as autonomous bridges connecting two buildings together.  The client is complaining that the performance is very slow across the wireless bridge. Since these access points are in autonomous mode I have to use the GUI of each AP to troubleshoot.  What is the best approach in trouble shooting this issue.
W
Rasika Nayanajith
I would SSH to those APs & issue "show dot11 association" & "show dot11 association <mac_addr>" to see details of the existing connection RSSI they see each other.
Also check  it is configured to use WPA2/AES, possibly some channel bond to 40MHz if it is in 5GHz band.
Sample command output show in below post
https://mrncciew.com/2013/11/09/wireless-bridge-with-eap-fast/
Rasika
*** Pls rate all useful responses ***
Thanks for the response and solution.  I will try this the next time I'm at the client site.
