04-26-2018 04:41 AM - edited 07-05-2021 08:34 AM
Hello, recently I upgrade wlc2504 to 8.2.166.0 and the AP's (30 uds) to the model AIR-CAP1602I-E-K9.
My wireless network have 2xSSID (both WP2 PERSONAL+TKIP, the same config in both except ssid'name and password obviously).
I did a test with my laptop directly in both router and get 300Mbs in both ways.
I connected my laptop in the switch and get same speed.
When I connect via wifi in both ssid the download speed connection is half than the upload speed.
Also, in one of the 2 ssid the speed is lower than connecting to the other ssid.
I applied best practices without improvement.
The test was with a laptop Windows 7 and one Macbook Pro
Any idea where can be the issue?
Solved! Go to Solution.
04-26-2018 01:32 PM
dmartinezrubio@gmail.com wrote:
Windows NIC: Broadcom BCM943228HMB 802.11 abgn 2x2
Just as suspected: The wireless NIC can only support 2x2:2.
04-26-2018 04:44 AM - edited 04-26-2018 04:45 AM
What is the exact make and model of the wireless NIC card?
Half the upload speed would make the wireless NIC to be 2X2:2.
04-26-2018 07:14 AM
MacBookPro: AirPort Extreme BroadCom BCM43xx 1.0
The speed test was:
Download: 10 Mbps
Upload: 80 Mbps
*Attach ssid configuration*
04-26-2018 07:18 AM
04-26-2018 07:23 AM
I did it with the mac and the speed was the same
04-26-2018 07:24 AM
04-26-2018 07:45 AM - edited 04-26-2018 07:50 AM
Using iperf over wifi against a server on the LAN was perfect, it is only when trying to navigate by Internet
04-26-2018 08:03 AM
04-26-2018 08:34 AM
All is in the same vlan.
The topology is:
FTTH ISP -> FW -> SW CISCO LEVEL2 RSTP-WLC CISCO
The vlan is the default vlan (management)....I reckon that it's not important, isn't it?
04-26-2018 07:21 AM
04-26-2018 01:32 PM
04-27-2018 01:01 AM
Any idea about the big difference between upload and download speed?
04-26-2018 05:01 AM
04-26-2018 06:17 AM
Sorry, WPA2 AES with PSK (and FT PSK)
04-26-2018 06:25 AM
