Hello everyone I hope you are fine ...
I had two quotations the first is about how to put a rule for accessing services using authentication methods such as Hotspot for access internet as an example ( I want to knew the others for applying them in a small LAN )
the other one is about that I had private range and public range of IP and there is same users need to use public IP in the LAN without using NAT and other users still work in private range
I used this topology for my LAN
