Small Question
Aolabi201
Community Member
Hello every one
how i can make the wireless network invisible in cisco wireless controller 2500
And Thanks
SHUBHAM GUPTA
Go to the desired WLAN and uncheck "broadcast" option under it.
BY unchecking the broadcast option, SSID will be hidden(invisible) but users can still connect to it after creating a wireless profile manually with the same name as of the SSID.
Do let me know if you have any queries or concerns.
Shubham
Please don't forget to rate the posts which answered your question and mark it as answered or was helpful
SHUBHAM GUPTA
Shubham
Thank you SHUBHAM GUPTA
