small router with Integrated 802.11n Access Point, which was ADSL2 ,3G also
robert.jubb
iam after a  Integrated 802.11n Access Point, which was ADSL2 ,3G , we used to use
CISCO887GW-GN-E-K9
I don’t thinks theres anything like the CISCO887GW-GN-E-K9 around -- what can i do use say a
887VAG+7. with a wireless access point plugged into it - regards
Scott Fella
Have you looked at the new ISR Gen 2. The 1941w might work for you. You just need to figure out what modules you need.
-Scott
