Smart licences types
akram.root
Level 8
Level 8
Hello all,
I am beginner in the world of cisco wireless , i need your help !
I have installed a controller 5520 with APs , and cisco prime infrastructure , all is good .
I have a different licences smart but i don't know how i have types of licences not use it (show 0 use )
i would like to know why ? and what is their importance ?
i  share with you bellow these types of licences
Best regards
Akram
6 Replies 6
Sandeep Choudhary
To use these licenses you must have a smart account and access either to your satellite or cisco cloud.
prime infrastructure 3.x assurance lic  --> Its used by Cisco Prime infrastructure to maange APs
CISCO DNA Essentials Term Licenses  --> Cisco WLC will use it
AP perpetual network stack essentials --> To use more advanced features , example:  https://www.cisco.com/c/dam/global/da_dk/assets/training/seminaria-materials/Licenses-Networking-for-everybody-with-DNA.pdf
Dont forget to arte helpful posts
Thank you for your reply ,
Why these licences not in use  (show 0 in use ) ?
I have already installed and used licences smart :
  • WLC 5520 or WLC 8540 or WLC 3504 Access point license .
  • prime Infrastructure 3.X Lifecycle Lic.
  • Prime Infrastructure 3.X BASE Lic
Best regards
Akram
Do you already connect your WLC/Prime to cisco cloud or to your sattelite (On-prem)  ?
Thank you for your return ,
I connected via internet .
I have installed a controller 5520 with APs , and cisco prime infrastructure , all is good , also i have  installed smart licences without problem :
My question I have  different  license smart , they are not in use (show 0 use ) :
  • Aironet DNA Essentials Term Licenses
  • AP Perpetual Networkstack Essentials
  • Prime Infrastructure 3.x, Assurance Lic.
If your device are connected to cisco cloud/smart account then:
If devices are using it then you will see IN USE else 0 will be there(Meas Cisco wlc or prime is not using these licenses).
Here is the screenshot from my account:
Dont forget to rate helpful posts
Thank you for your reply.
But what is the importance for these licences in my situation ?
I buy it bat i can't use it why ?
Best regards
Akram
