SNMP v3 with HA monitoring with SolarWinds
craiglebutt
Level 4
Level 4
Have several 8500 and 5520 in HA, we monitor both active and standby WLCs using SNMP v2 in Solarwinds.
Had to start to monitor using SNMPV3
The 8500s are running 8.5.182.104 - I can monitor both Active and Stanby WLC with SNMPv3
The 5520s are running 8.10.171.0, - I can monitor the Active on SNMP v3, but the Stanby is still on V2.
Connet to standby and run sh snmpv3user and the config is there for it
(Cisco Controller-Standby) >show snmpversion
SNMP v1 Mode.................................... Disable
SNMP v2c Mode.................................... Disable
SNMP v3 Mode.................................... Enable
But Solarwinds is still monitoring on V2.
I know in earlier versions did say might have to reboot for v3 to take affect, but not had to do that for any other WLCs
Any ideas?  To confirm I have got the correct IPs.
Cheers In advance
Arshad Safrulla
If the behavior is same even after a reload of both WLC's, I would first open a call with SolarWinds. If they feel the issue is from Cisco side then speak to TAC.
