Software downloads for Aironet 350 Wireless LAN Adapter
j.sprogis
Where can I get the software to install the Aironet 350 Wireless LAN Adapter? Will it have a client manager? I think that's what the software is to switch settings as you change locations.Model: AIR-PCM352
inayathulla1
You can download the software from the below link using your CCO login:-
http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=278875243
Cisco Aironet Wireless LAN Client Adapters
Cisco Aironet 340 Wireless PC Card Adapter
Cisco Aironet 340 Wireless PCI/LMC Adapter
Cisco Aironet 350 Mini-PCI Wireless LAN Client Adapter
Cisco Aironet 350 Wireless LAN Client Adapter
Cisco Aironet 5 GHz 54 Mbps Wireless LAN Client Adapter (CB20A)
Cisco Aironet 802.11a/b/g CardBus Wireless LAN Client Adapter (CB21AG)
Cisco Aironet 802.11a/b/g PCI Wireless LAN Client Adapter (PI21AG)
Plz rate if this help.
Inayath Shariff
inayathulla1
Inayath Shariff
