Some client data not being populated after upgrading to NCS 1.1.0.58
eajackson
After upgrading to Cisco Prime NCS 1.1.0.58 some of the client data is not being populated or gathered. The graphs labeled "Client Count By Association/Authentication" and "Client Count By Wireless/Wired" are no longer being updated? Not sure what was changed during the upgrade or where to look to get it to start collecting the data again?
Scott Fella
Eajackson,
Make sure your WLC, MSE and WCS/NCS code matches the compatibility matrix here:
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
-Scott
That was it. Thanks.
Glad you got it working!
-Scott
I think I spoke to soon. All of the codes match now but it is still not pulling in the client data?
