5500 ap lic upgrade problem
john smith
Level 5
Level 5
hello friends,
i am facing a problem to install a ap upgrade lic file on controller 5500
i am getting the follwoing error
% Error: License file transfer failed - Error from server: File not found
i have confusion here that
when i configure this comand from GUI
tftp://172.32.45.22/cmm/standard.lic
what i sould use for /cmm/  ????
let say i have lic. file is on desktop of tftp server computer
and i say in this comand
tftp://10.12.70.35/??/license file .lic
thanks
Scott Fella
Let me clarify... If your license file is on your desktop, then you would configure or set your root tftp folder to your desktop. Then all you have to do is:
tftp://172.32.45.22/license.lic
Assuming your tftp server ip is 172.32.45.22
-Scott
6 Replies 6
john smith
Level 5
Level 5
please some one reply for this
its urgent for me
what i should use for /cmm/ ??
thanks
It depends on where your tftp root folder is. If you place the lic file in the tftp root, you do not need to specify a directory. Configure your tftp server correctly.
Ex.
tftp://10.10.20.10/license.lic
Or in your case:
-Scott
thanks for you reply
i really appreciate your support
but what are the meanings of this word in comand
/cmm/     ????
but i would type if i have a lic. file on my desktop?
thanks
That a directory named cmm. So the license file is placed in the root folder/cmm
-Scott
Scott Fella
-Scott
thank you Fella for your support
actually the best practice is to just keep the lic. file in tftp server's directory folder
and use the same comand from GUI
thanks
