Spaces Telemetry issues
I'm trying to get environmental stats back from 9136/9166 on Spaces. I've imported the maps successfully and have enabled the IOT service in spaces. I'm still getting errors for the TDL Telemetry under the troubleshooting section which seems to be preventing adding the APs as sensors.
CHECK WLC SUBSCRIPTION
87 APs on the WLC have not sent any data in the last 120 mins. Please check if wlc subscriptions have been created. Run on wlc terminal: show telemetry ietf subscription all. Subscription ids 122-127 should show as Valid.
I'm not sure what part of the process creates the subscriptions
Mark Elsen
                                 >...Subscription ids 122-127 should show as Valid.
                                     You should then for instance check :
            show telemetry ietf subscription       122 detail       (and the others till 127)
            show telemetry internal connection 122 detail        (and the same here)
                      Other useful commands
            show telemetry internal subscription all stats
            show telemetry ietf subscription configured
            show iox detail
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hi Marce,
Thanks for replying, the Spaces IDs 122-127 are not there. It looks like the rest are DNAC related subscriptions. Pretty sure we have followed all the configuration steps.
 - Check controller software version ; as an example : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwf44321
    even mentions 17.12.2 as a fixing release...
 M.
Just an FYI for anyone else with the same issue. I had to remove the line  - netconf-yang feature candidate-datastore
As per the post  Solved: Having Problemas Editing a File NETCONF - Cisco Community
Spaces can now see the APs vor environmental information
