Spanning Tree on Radio sub interface
john.mcmanus
Community Member
I have a 1801 ADSL router.
I have a Bridge group 2 configure with a BVI interface, this is also bridge onto VLAN 2 so I have a server on VLAN 2 which acts as a media server.
when I connect to the WLAN I can get to the internet. But cannot connect to the server which is on the same vlan. when I do a show spanning tree I can see it is disabled on the dot11radio0.2 interface.
I remove the bridge-group 2 spanning disable and sure enough everything works.
on reboot spanning tree is disabled again.
Should I be doing this a bit differerntly to joing vlan 2 and the radio interface?
any ideas.
John
0 Replies 0
