SRE Wlan configuration
dumisanid
Community Member
I purchased a cisco2901 and added a SRE so as to add the WLAN module. I need to know If any of you have ever had to configered this bo know how before.
I just need to know how we unable Http access from the CLI for the WLAN module.
regards
George Stefanick
can you post the show run ? On a normal ap its
this is show run output from the SRE module
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.116.0
RTOS Version..................................... 7.0.116.0
Bootloader Version............................... 7.0.116.0
Emergency Image Version.......................... 7.0.116.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_6a:8d:c0
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1230
IP Address....................................... 192.168.4.10
System Up Time................................... 0 days 0 hrs 22 mins 41 secs
System Timezone Location.........................
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Next Boot License Type........................... Permanent
--More or (q)uit current module or to abort
THIS IS THE RUNNING CONFIG on THE ISM INTERFACE
interface ISM0/0
ip address 192.168.4.1 255.255.255.0
service-module ip address 192.168.4.10 255.255.255.0
!Application: Running
service-module ip default-gateway 192.168.4.1
end
BUT MY PING to 192.168.4.10
Lodge_Router#ping 192.168.4.10
Sending 5, 100-byte ICMP Echos to 192.168.4.10, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Can you guys shed some light in to this?
HTTPs is by default enabled on SRE module.
WLC>show network summnary -- Look for web mode and check the status.
WLC>config network webmode enable
ISM0/0 is to pull the software package for SRE, use ISM0/1 for wireless.
interface ISM0/0
ip address 10.1.1.2 255.255.255.0      !Service module host side IP address
ip nat inside  !To establish connectivity between SM and outside network for installation
ip virtual-reassembly in
service-module ip address 10.1.1.3 255.255.255.0 !Needed for WLC installation
service-module ip default-gateway 10.1.1.2       !Host side IP address
hold-queue 60 out
interface ISM0/1
description Internal switch interface connected to Internal Service Module
switchport mode trunk    !Used for connectivity to Wireless Controller after installation
SRE on Router can be deployed/support different scenarios.
http://www.cisco.com/en/US/docs/wireless/controller/controller_modules/sre/installation/guide/wlcsreinst.html
