ssh access (only) from wireless connection
goncalo.girao
Level 2
Level 2
Is it possible to restrain acess from ssh (CLI) without enable GUI acess from wireless lan?
Thank you
Stephen Rodriguez
Yes, you need to put a CPU acl on the WLC that restricts that access
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Here is a config example
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a0080a7c988.shtml
If you find this helpful rate useful post !
thanks
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Saravanan Lakshmanan
enable management via dyn interface.
Fyi, cpu ACL is global and applicable for both wired and wireless management.
are you trying ssh to virtual ip from wireless client.
