04-23-2010 07:23 AM - edited 07-03-2021 06:45 PM
I am deploying a Uniified wireless Communication Network that spans two location (Head Office and Branch Office) using 1xWLC 4402 and 13x1252 APs. Is it possible to configure the APs at the branch office to broadcast ssid that wouldn't be broadcasted on the head office APs on the WLC.
Ola
Solved! Go to Solution.
04-24-2010 10:03 AM
Hi, you could use "WLAN overwrite" to do that.
Here the instructions for it ..... search for "Enabling WLAN Override" in the document to get to the right paragraph....
http://www.cisco.com/en/US/docs/wireless/controller/4.0/configuration/guide/c40wlan.html#wp1089232
04-24-2010 10:03 AM
04-24-2010 11:14 AM
Thanks!! The link you specified is very useful, that was exactly what I needed.....
