SSID Creation issues
Daniel Anderson
Level 2
Level 2
Over the weekend I upgraded a No. of 4402 Wireless LAN controllers to Code 7.0.220.0, the upgrade went smoothly with all Access Points migrating over, the existing SSIDs that were in place prior to the upgrade are functioning as expected today.
However, this morning, I've created a new SSID and set to Broadcast out on all our LAN Controllers, but I'm unable to see the network as expected. I've browsed for the network from a No. of different laptops and smartphones, and none are able to see the new SSID advertised. I've connected to the CLI of the devices in question, and running 'show wlan summary', shows the newly created SSID and confirms that it's in the enable state.
Is there something blatant I've missed with regards creating an SSID on this code version, we were previously on an old Version 4 code, and never had any issues on this firmware when creating SSIDs.
Any help/input much appreciated
TIA
Dan
17 Replies 17
Be careful, because if you move AP's to a different AP Group, the ap will reboot.
Scott Fella
Sent from my iPhone
-Scott
Dan,
Just to toss in 2 cents on Scotts 10 dollars worth of inforamtion. When you use AP groups you will need to make 100% sure the name of the groups are IDENTICAL on all controllers. If an AP moves from a controller with one AP group and that AP group is not named the same including "spaces" on the back up controller the AP falls back into the default group .
Thanks George - I'll triple check them all tonight.
