ssid key
cisco.plus
Level 3
Level 3
hello
On a wlc 5500 the ssid key is stored in ASCII format so on a windows 7 PC the wireless key is stored in which format?
possible to copy the windows 7 PC key directly to the wlc ssid key incase of mistakenly changed the key in controller
cheers
CP
In Windows 7 is will show the ASCII and that you can cut and paste. Just click in show in windows 7 and it will show you the pre shared key.
-Scott
7 Replies 7
Scott Fella
What are you actually talking about. Pre shared key?
-Scott
sorry mate for incomplete info, its Pre Shared Key i was referring about
-Scott
once I cut / copy the key from Windows 7 PC and paste on the controller it gives me error too long key. i am pasting it under section 'Security'  / Layer2 /  PSK Format - ASCII
The key is 69 character in Windows 7
Well that might be the problem. The key is too long.
-Scott
Scott Fella
WPA preshared keys must contain 8 to 63 ASCII text characters or 64 hexadecimal characters.
-Scott
Thanks a Million
