SSID limitation
danhosking
I have a client with an existing autonomous wireless network. We are looking at ways to keep the existing SSIDs ( they currently have 18 and this will grow in the future ). They are looking at migrating to an LWAPP solution but we are running into difficulty with the 16 SSID limit on the 4404 WLC. They will be running approx 5 SSIDs on any given AP. Is there a way to create more SSIDs on the WLC and assign them to groups of APs?
jeff.kish
Level 7
Level 7
About the only thing you can do is have multiple controllers with different SSIDs configured. Then assign access points to the appropriate controller to obtain the SSIDs they need.
You can only create 16 SSIDs per controller, though. It's a pain :/
5 Replies 5
jeff.kish
Level 7
Level 7
Yeah this is the same conclusion I came to. Apparently there is a feature in 5.2 that may help with this limitation.
Yeah... what I know it that 5.2 will allow you to create more that 16 ssid's, the ap is the deciding factor on how many ap's will be supported. We shall see if it actually comes out on 5.2.
-Scott
Wow, can't wait for that.
I'll give Cisco credit - they seem to be constantly knocking down the annoying barriers that exist in LWAPP. First the 8-SSID limit, then the 3 H-REAP limit, and now maybe more SSIDs.
Yeah right... I know this was due to situations where clients had more than 16 ssid's throughout their campus.... but again... lets see if it cames out and how stable the code will be. Again, this is suppose to combine the mesh train also.... so that means more code!
-Scott
