How to add antenna types to WCS
ericgarnel
Level 7
Level 7
OK,
Maybe I missed this, but WCS is selecting the wrong b/g antenna by default and does not contain the exact antenna I have in the pull down menu.
I am running 4.2.110.0 with loc 3.1.42 and
4.2.173.0 on my wisms
Eric
ivillegas
Level 6
Level 6
Try these steps.
1. Choose Monitor > Maps, and select the floor where the AP heat maps do not show up.
2. Go to position aps in the drop-down list on the far right.
3. Select the AP where the heat maps do not work.
4. On the left, choose Other for the Antenna Type, and click Save.
5. Go back to the Antenna Type and select the same antenna that it orginally used, and click Save again.
Nope, that did not work. I will still have to use a different antenna with similar properties
