SSID not seen as the same SSID
I have autonomous APS with SSID - XX and LWAP SSID - XX both WPA2 and they are seen as two different signals? When they were set up as WEP users had no problems connecting to both and roaming from both?
scottmac
Level 10
Level 10
Make sure there's no leading or trailing spaces, double space, or other non-visible characters in one SSID or the other ... all characters are significant, even ones you can't see.
Good Luck
Scott
