SSID Signal Strength
Faisal Shabbir
Hi fellows,
i have two questions i would appreciate if someone answer .
Q1: why an AP shows different signal strength (percentage)  of different SSIDs since its broadcasting all SSIDs ?
Q2: how you categorize excellent/ goodf fair bad signal strength of SSIDs (percentage) ??
abwahid
Level 4
Level 4
Because signal strength is matter on what objects (walls, doors, furniture, electrical equipment/outlets) interferences are in the coverage, which is not remain same in all directions and all the time, AP shows the percentage of signal strength on real time basis.
Q2: how you categorize excellent/ good fair bad signal strength of SSIDs (percentage) ??
Actually the measure of a connection depends on both the Signal Strength and Signal Quality. RSSI is a measure of Signal Strength, while CINR, SNR measures of Signal Quality
Signal Strength
RSSI = Received signal strength indicator (measured in dBm)
Excellentabove −65 (closer to 0 is better)
Good−65 to −75
Fair−75 to −85
Poorbelow −85
