SSL Certificate Signed using Weak Hashing Algorithm - Cisco WLC - Port 16113
KarthikVandanapu
Frequent Visitor
Frequent Visitor
Platform family -- Cisco
Platform details -- Cisco WLC
Plugin name -- 1. SSL Certificate Signed using Weak Hashing Algorithm
                         2. SSL Certificate Cannot Be Trusted
Port              -- 16113
Protocol       -- tcp
Above is the vulnerability finding in internal audit and we have applied "
“config network secureweb cipher-option high enable” and rebooted WLC but still audit team says Port 16113 is still open. wanted to know how to block 16113 and is there any impact due to this.
Scott Fella
That port is for CMX NMSP. I ran into that issue also with a pen test. It depends on the security folks if it’s okay or not. They were okay with me enabling the higher ciphers but still didn’t like the 3des but mentioned when TLS1.3 is out that they expect no other to be enabled. Don’t really think that is possible because of backwards compatibility. They know this too.
-Scott
O_H
Level 2
Level 2
Did you find a solution for this?
I think that {config nmsp cipher-option high enable} should solve it. But my confusion is that it says it is already enabled while in the {show nmsp status says it is disabled}. Also Cisco says this command is introduced in 8.8.11.0 but i run 8.5.171.0.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-8/cmd-ref/b-cr88/config_commands_j_to_q.html#wp2182172882
