startup problem with encryption
mndad
Community Member
Trying to configure my Aironet adapter (AIR-CB21AG-A-K9) with my home access point, but am having a slight problem. When unencrypted, it finds the AP and connects right up. When I add encryption (WP AES), it doesn't connect automatically. It just keeps scanning . I basically have to modify the profile setting (just changing the valid wireless modes on/off) get's it to connect. Have to go through this same process each time wireless is re-enabled. Any suggestions?
scottmac
Level 11
Level 11
Are you using the Cisco client software, or Microsoft Zero Wireless Config?
If you are using the Cisco client software, what version are you using?
Let us know
Scott
mndad
Community Member
I'm using the Cisco Aironet Desktop Utility.
Config Utility 3.00.296
Appl Interface 3.00.296
Auth Interface 1.0634.5
Auth Protocall Driver 1.0.0.44
Wireless Device Driver 3.0.0.104
