Static IP address for Guest Wired network
Not applicable
I setup a guest wired network on the WLC 5508 with 7.2.110.  A postage machine can only be setup for static IP address over guest wired network.  Is any one how to get it configure on the WLC 5508?
Stephen Rodriguez
So, you configured a 'wired guest' network, and need to assign a static IP to the device?
You should be able to assign an address from the egress interface range, as up to the WLC it's just a L2 link
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Steve,
A client device need a static IP address within the DHCP range from the WLC.  Is it possible to assign a static IP addresses within DHCP range on the WLC.
Eric
Yes and no. Yes you can use the same subnet, but you would need to exclude the static address so that it can't be given out.
Steve
HTH,
Steve
