Static Routing on 2106 controller
Hugo Lynch
Visitor
after an unplanned power outage the WLAN in our office has stopped routing.  Clients can associate and get an IP address from the DHCP server on the controller but cannot get past the controller.  A PC on the LAN can ping the default gateway of the SSID (dynamic interface) but cannot ping the client.  Attached is a diagram of the setup.  I am trying to find out how to add a default/static route via the L3 switch that the controller is connected to but am unable to do so either through the CLI or GUI.  Am I missing something?  The controller (AIR-WLC2106-K9) is operating on ver 5.2.157.0.
Thanks for any advice,
Hugo
pcroak
Hello Hugo,
The WLC is not a routing platform -- it connects to your switching infrastructure at Layer 2. The network routes you see in the CLI are meant for the service-port only -- which the 2100 platform does not have (so actually the show route summary command should not be there).
Could you send us the "show interface summary" from the WLC? We also would want to see your current switchport config where the WLC is connected (show run interface fast/gig x/y ...). Lastly, we would want to confirm your L3 interface configuration on the switch with a "show ip interface brief".
Based on your static route, it looks like you are trying to route traffic to the WLC -- this is not the intended functionality -- your switch/router should perform the routing and the connectivity to the WLC will be a L2 trunk.
-Pat
5 Replies 5
pcroak
Hello Hugo,
-Pat
Hi Pat,
here is the interface summary and interface vlan11
(Cisco Controller) >show interface summary
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Guest
ap-manager                       1    untagged 10.6.0.244      Static  Yes    No
management                       1    untagged 10.6.0.243      Static  No     No
virtual                          N/A  N/A      1.1.1.1         Static  No     No
vlan11                           1    11       10.6.5.250      Dynamic No     No
vlan21                           1    21       10.6.6.250      Dynamic No     No
vlan30                           1    30       10.6.7.250      Dynamic No     No
(Cisco Controller) >show interface detailed vlan11
Interface Name................................... vlan11
MAC Address...................................... 00:21:55:9a:35:40
IP Address....................................... 10.6.5.250
IP Netmask....................................... 255.255.255.128
IP Gateway....................................... 10.6.5.250
VLAN............................................. 11
Quarantine-vlan.................................. 0
Physical Port.................................... 1
Primary DHCP Server.............................. 10.6.0.243
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... No
Guest Interface.................................. No
The switch is an Enterasys switch so I guess the information you want to see is the following:
router
enable
configure
ip route 0.0.0.0 0.0.0.0 10.203.1.1
ip route 10.6.5.128 255.255.255.128 10.6.0.243
interface vlan 200
no shutdown
ip address 10.6.0.251 255.255.255.128
exit
#vlan
set vlan create 11
set vlan create 200
set vlan egress 11 ge.1.38-40 tagged
set vlan egress 200 ge.1.38-40 untagged
The AP is connected to interface ge.1.38 and the WLC is connected to interface ge.1.40
Cheers,
Hugo.
Hi Hugo,
Alright, so, you are going to need to configure L3 interfaces on your switch for your other vlans (11, 21, 31). Again the WLC does not perform routing -- if you look at your vlan 11 interface details, the gateway is pointing to itself -- this gateway needs to be your router address for that subnet (which should be interface vlan 11 on your switch).
You will also want to remove your "ip route 10.6.5.128..." statement, because you should not send these packets to your WLC management interface. The WLC will communicate with your switch as a L2 trunk, the routing should all occur on the Enterasys switch in this case.
http://www.cisco.com/en/US/docs/wireless/controller/5.2/configuration/guide/c52mint.html#wp1117889
This picture explains how the WLC interfaces should operate with the connected switch. Please let me know if you have questions regarding this information.
-Pat
Hugo,
     Generally when working with L3 devices, you shouldn't need to have a static route for a VLAN that the devices has configured on it.
so in this case you shouldn't need the ip route 10.6.5.128 255.255.255.128 10.6.0.243
If vlan 200 exists at L3 on the switch, it should route for it with the need for a static route.
**as an aside, the network routes on a WLC are to force traffic out of the service port, as it does not have a gateway address.**
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Hi Pat,
since your reply I have created a L3 interface for vlan 11 on the switch of 10.6.5.251 and have modified the scope for vlan 11 on the DHCP server on the controller to show a new default gateway of 10.6.5.251.  The client can now route to the big bad www.  Many thanks for your help.
Hugo.
