Static WEP and EAP
iegould
Community Member
Is it possible to run static WEP keys and EAP together on the same AP for authentication ? I believe this is possible but I have not tested this, has anyone else ? I'm planning migrating to EAP from static WEP keys, this would make the migration plan very simple.
Not applicable
You cannot use static WEP keys with EAP-TLS. You can use either EAP or Static WEP keys.
