Strange error configuring 1041N
markmather
Visitor
Hi folks, I bought a Cisco 1041N at a trade show and am now trying to configure it?
I bought two serial cables through Amazon which are specific to Cisco:
https://www.amazon.de/-/n...o2ov_dt_b_product_details
https://www.amazon.de/dp/...o2ov_dt_b_product_details
I have installed the drivers for these cables and have updated Windows. Then I tried to establish a connection from my computer with Putty.
With the first cable I can't seem to get a connection at all. With the second cable I get a connection. I see the 1041 startup screen and see the entire startup process. However, when I give commands myself, there is a huge delay between the input and what appears on the screen. Also, some of the keystrokes i enter displayed on the screen in different graphical characters and thus the commands to set the AP are not executed!? What is going wrong, who can help me? best regards Mark
10 Replies 10
Scott Fella
I have only used the FTDI USB-C to RJ45 cable:
https://www.amazon.com/OIKWAN-Adapter%EF%BC%8C-Essential-Accessory-Ubiquity/dp/B08F7VY86M
Now you need to make sure that you have the Putty configuration set to 9600.  Take a look at this doc.
https://community.cisco.com/t5/wireless-mobility-knowledge-base/how-to-console-into-cisco-aironet-access-points-and-bridges/ta-p/3131312
-Scott
Scott Fella
My suggestion is to paste a screen shot of your settings in putty and some of the output you are seeing.
-Scott
My Putty settings are standard as in this image
Rich R
There are many cables which don't work.  This one works for me:
https://www.amazon.de/gp/product/B07MYQPYKR/
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Scott Fella
If you still have this issue, put the ap in common mode and reset the baud, incase that was changed.  Search the internet for , "cisco ap rommon unset BAUD"
-Scott
What do you mean by "put the ap in common mode"?
I think that should be ROMMON as per what Scott said to search for.
markmather
Visitor
I am uploading a few screens which I get while the AP is booting and the final screen is an example of the garbage I see when trying to type in commands.
Looks like your terminal settings are ok but most likely a cable problem.
Check that the COM port advanced settings has all the buffers etc set for high speed.
Sometimes playing with the flow control setting can help.
markmather
Visitor
I tried to restart the device twice to give you a more accurate view of what is displayed during bootup and what happens when I try to enter commands.
flashfs[0]: 147 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 5680640
flashfs[0]: Bytes available: 26704384
flashfs[0]: flashfs fsck took 23 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: d4:8c:b5:d2:47:3e
Waiting for PHY auto negotiation to complete... done
Ethernet speed is 1000 Mb - FULL duplex
Loading "flash:/c1140-k9w7-mx.124-25d.JA1/c1140-k9w7-mx.124-25d.JA1"...######### ################################################################################## ################################################################################## ################################################################################## #######################################################################################################
File "flash:/c1140-k9w7-mx.124-25d.JA1/c1140-k9w7-mx.124-25d.JA1" uncompressed and installed, entry poi
executing...
enet halted
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C1040 Software (C1140-K9W7-M), Version 12.4(25d)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 11-Aug-11 02:58 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
FLASH CHIP: Numonyx P33
Checking for Over Erased blocks
flashfs[1]: 147 files, 7 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32126976
flashfs[1]: Bytes used: 5680640
flashfs[1]: Bytes available: 26446336
flashfs[1]: flashfs fsck took 7 seconds.
flashfs[1]: Initialization complete.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 11999232
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 11998208
flashfs[2]: flashfs fsck took 1 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
Radio0 present 8363 8000 90020000 0 90030000 B
Radio1 not present 0 0 0 0 0 0
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-AP1041N-E-K9 (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1630Z4BG
PowerPC405ex CPU at 333Mhz, revision number 0x147E
Last reset from watchdog timer expired
1 Gigabit Ethernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: D4:8C:B5:D2:47:3E
Part Number : 73-14034-05
PCA Assembly Number : 800-34273-06
PCA Revision Number : A0
PCB Serial Number : FOC16272MQN
Top Assembly Part Number : 800-34284-04
Top Assembly Serial Number : FCZ1630Z4BG
Top Revision Number : A0
Product/Model Number : AIR-AP1041N-E-K9
Press RETURN to get started!
*Mar 1 00:00:10.014: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar 1 00:00:10.028: *** CRASH_LOG = YES
*Mar 1 00:00:10.328: Port 1 is not present
*Mar 1 00:00:11.044: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interfa
*Mar 1 00:00:13.329: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:14.329: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state t
*Mar 1 00:00:22.333: AUTOINSTALL: GigabitEthernet0 is assigned 192.168.1.54
*Mar 1 00:09:40.001: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar 1 00:09:40.001: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar 1 00:09:41.000: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to dow
*Mar 1 00:09:46.058: %SYS-5-RESTART: System restarted --
*Mar 1 00:09:46.058: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar 1 00:09:47.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:09:55.157: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.1.54, mask 2
ap>enb▒e
Password:
f▒cotmnl▒Xl▒#ap#
ap(config)#d▒▒▒▒
ap(config)#c
ap(config-ssid)#
% Invalid input detected at '^' marker.
ap(config-ssid)#▒iguration commands:
accounting radius accounting
authentication authentication method
dot1x SSID Config Commands for IEEE 802.1X
exit Exit from ssid sub mode
guest-mode gu▒
ap(config-ssid)#tt
ap con0 is now available
Press RETURN to get started.
▒▒a▒p>▒a▒p>
at>
ap>ap>▒
ap>▒ab
Password:
using eeprom values
WRDTR,CLKTR: 0x83000800 0xc0000000
RQDC ,RFDC : 0x80000038 0x00000185
using ▒▒▒▒ ddr static values from serial eeprom
ddr init done
IOS Bootloader - Starting system.
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x83000800, 0xc0000000
RQDC, RFDC : 0x80000038, 0x00000185
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is NOT up.
PCIE1 port 1 not initialized
PCIEx: initialization done
Loading "flash:/c1140-k9w7-mx.124-25d.JA1/c1140-k9w7-mx.124-25d.JA1"...#########################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1140-k9w7-mx.124-25d.JA1/c1140-k9w7-mx.124-25d.JA1" uncompressed and installed, entry point: 0x4000
executing...
enet halted
cisco Systems, Inc.
[email protected].
1 802.11 Radio(s)
*Mar 1 00:00:10.015: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar 1 00:00:10.029: *** CRASH_LOG = YES
*Mar 1 00:00:10.329: Port 1 is not present
*Mar 1 00:00:11.045: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0Base Ethernet MAC address: D4:8C:B5:D2:47:3E
*Mar 1 00:00:13.330: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:14.330: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:22.334: AUTOINSTALL: GigabitEthernet0 is assigned 192.168.1.54
*Mar 1 00:09:41.001: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar 1 00:09:45.556: %SYS-5-RESTART: System restarted --
*Mar 1 00:09:45.557: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar 1 00:09:46.518: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:09:54.656: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.1.54, mask 255.255.255.0, hostname ap
ap>e
% Password: timeout expired!
Password:
Password:
% Bad secrets
ap>ena▒▒e
▒rbn~▒▒▒▒▒▒▒▒▒
