Strange issue with Cisco 2602 AP's
Shahab Khan
A client is having Cisco 1131 & 2602 AP's installed. His laptop only support 802.11a/b/g. When the client is connecting through Cisco 1131 & trying to download a file from a shared server within his organization, he is able to download 30MB file in less then 5 min. But when downloading the same file from same server while connecting with 2602, it is taking approx 25 min to download.
Both the AP's were connected to the same switch, same port.
Shahab
5 Replies 5
Did you check the client connected  data rate in those two scenario ?
Are they autonomous AP or CAPWAP ?
Rasika
Hi Rasika,
They are CAPWAP. With both the models it is 54Mbps.
Ok, then post "show client detail output from your WLC while you are doing this testing (1st output when it is connected to 1131 & the 2nd output when it is connected to 1262)
This output will provide all the information required to see what's the difference of client connection
Rasika
Please find attached output files
Based on the output, we can see client connected 54Mbps rate to 2602 (even though you experience slow file transfer rate) where as 48Mpbs to 1131 (you got much better file transfer rate).
One other thing I noticed is with 2602 EAP Type shown as TTLS where as 1131 shown as 0. Is it possible to create a test WLAN with Open Authentication & do a similar test ?
Also veryfy switchport connected to 2602 is Full duplex/1Gbps . (show interface x/x will confirm this)
With 2602AP
QoS Level........................................ Silver
802.1P Priority Tag.............................. disabled
WMM Support...................................... Disabled
Power Save....................................... OFF
Current Rate..................................... 54.0
Supported Rates.................................. 1.0,2.0,5.5,11.0,6.0,9.0,
    ............................................. 12.0,18.0,24.0,36.0,48.0,
    ............................................. 54.0
Policy Type...................................... WPA2
Authentication Key Management.................... 802.1x
Encryption Cipher................................ CCMP (AES)
Management Frame Protection...................... No
EAP Type......................................... TTLS
Interface........................................ XYZress users
VLAN............................................. 144
Radio Signal Strength Indicator............ -64 dBm
Signal to Noise Ratio...................... 32 dB
With 1131AP
Current Rate..................................... 48.0
EAP Type......................................... 0
Radio Signal Strength Indicator............ -51 dBm
Signal to Noise Ratio...................... 46 dB
Rasika
**** Pls rate all useful responses ****
