Study
fb_webuser
Level 11
Level 11
How long is a complete CISCO study, till im proffesional!
Posted by WebUser Alroy Ndhlovu
abukuru95
Level 6
Level 6
Hi Alroy, It all depends on what you want to pursue. there are a wide range of cisco certifications but keep in mind that CCNA is the basic foundation and a prerequisite to most of the higher certifications.So go for the CCNA and then think later what you want to do. You have voice, wireless, security and routing and switching professional certifications.
check out this link
http://www.cisco.com/web/learning/le3/learning_career_certifications_and_learning_paths_home.html
rate if this helps!!!
