Sup720 and WiSM module
landovalbo
Community Member
I want to install the Sup720 and the WiSM module, I know I have to create a VLAN that is used to communication between WiSM and Catalyst Sup720, then I have to create a DHCP Scope for the service port of the WiSM in the Sup720 and associate the VLAN for the service port......
Here is where I request your help:
It is possible to assign static IPs instead of configuring a DHCP Scope for the WiSM or not? If it possible how?
I did not find any documents of that!!
Thanks in advance
Fer
Stephen Rodriguez
Fer,
it is possible to statically assign the addresses to the SUP 720. You would need to console into the WiSM, and go through the initial setup. In there, you are prompted to do DHCP or none for the Service Port. If you select none, you are able to put a static address on it.
Personally I think the best way to do this, is to do the DHCP scope on the SUP. This way, if you need to replace the controller, or are in a remote location, you can simply session into the processor and get it back online. But that is up to you. One thing that you need to remember, is that in the WiSM the Service Ports are only used to communicate between the WiSM and the SUP, so whatever VLAN you use, should be an unused and unrouted subnet, that is only on the SUP the WiSM is in.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
Fer,
HTH,
Steve
