10-30-2006 01:46 PM - edited 07-03-2021 01:09 PM
How does one confirm, change, control the speed/duplex setting on the 1500 RAP?
Is the setting fixed? How is its setting?
10-30-2006 05:15 PM
all of the LWAPP AP's should be connected to swtich ports that are set to speed/duplex auto. The AP will negotiate to get to it's desired settings.
10-31-2006 08:02 AM
Is there any way to confirm the negotiation worked correctly?
11-01-2006 12:46 PM
you can do a show interface on the switch, and see what it is running at. if you look in the buffer, you will see messages about mismatch if they are not in synch. Of course the easiest way, is if the RAP is up and running, all should be ok.
