SWAPPING AP TO ANOTHER CONTROLLER
mshelton1
Community Member
How do you swap a large number of APs from secondary controller to primary controller.
Sent from Cisco Technical Support Android App
5 Replies 5
Scott Fella
I either use WCS, NCS, or Prime. Or I would script it using excel.
-Scott
mshelton1
Community Member
Yes but how?
Where can I find the steps to do it
If you have WCS,NCS or Prime, you create a access point template to change the primary, secondary and or tertiary WLC.
The other way is to figure out the command for the CLI and either script it or use excel to help create you script. You would need the names of all the APs. No document for that.
-Scott
check this link:
http://www.cisco.com/en/US/partner/docs/wireless/wcs/6.0/configuration/guide/6_0temp.html#wp1427622
please make sure to rate correct answers
mshelton1
Community Member
Yes I tried to use a template but wasn't able to list my Aps (under select AP). It would indicate 'too many AP' Is there a way to refine my search criteria? Thanks
