Switch 9200 not proving enough power to AP 2802
ittechk4u1
Level 4
Level 4
Hello Experts,
My Cisco AP 2802 connecte dto 9200-48P swicth and getting only 15.4 watt power.
Here is the output of show power inline command:
Gi1/0/43 auto on 15.4 Ieee PD 4 30.0
SW5#sh power inline gigabitEthernet 1/0/43 detail
Interface: Gi1/0/43
Inline Power Mode: auto
Operational status: on
Device Detected: yes
Device Type: Ieee PD
IEEE Class: 4
Discovery mechanism used/configured: Ieee and Cisco
Police: off
Power Allocated
Admin Value: 30.0
Power drawn from the source: 15.4
Power available to the device: 15.4
Any suggestions?
Thanks in advance.
19 Replies 19
Sandeep Choudhary
did you enable cdp on swicth or on port level ? If not then do it and try again.
Dont forget to rate helpful posts
I was about to reply the same point. Which made me think ... if this relies on CDP, then if you connect the same WAP to a battery pack for a site survey, how do you ensure that the AP gets the correct power? Just curious.
I have a few AP’s from 4802’s to 9100’s connected to Meraki using LLDP and a 3850 using cdp. Power draw shown on my Meraki shows lower than what I typically see on Cisco switches, but on the controller, the aps do show full power. That is where I tend to check it anyways. Funny thing is that I typically have used a batter pack which I have a power injector connected to it to power up any ap that I have used to survey. No matter what, once I have the ap up, I also check to see is the ap is getting full power or not.
-Scott
Thank you for your answers but AP is not coming up or not showing in WLC itself.
Well then provide more info. What controller and image, do you have other aps joined and also joined for the same switch? Help us better understand the issue.
-Scott
WLC Model:  5520
WLC SW: 8.5.151.0
AP: 2802I
We have three switches in stack and rest of the two switch are working fine.
Only 1st switch is having issue.
Also, make sure the cabling is good. Test the cable or use the TDR command:
https://community.cisco.com/t5/networking-documents/how-to-use-time-domain-reflectometer-tdr/ta-p/3119327
-Scott
here is the tdr result:
SW5#show cable-diagnostics tdr interface gigabitEthernet 1/0/43
TDR test last run on: July 20 08:38:26
Interface Speed Local pair Pair length Remote pair Pair status
Gi1/0/43 1000M Pair A 2 +/- 10 meters Pair B Normal
                           Pair B 2 +/- 10 meters Pair A Normal
                           Pair C 2 +/- 10 meters Pair C Normal
                           Pair D 2 +/- 10 meters Pair D Normal
Leo Laohoo
Post the complete output to the command "sh interface Gi 1/0/43".
Please find here.
SW5#sh interface Gi 1/0/43
GigabitEthernet1/0/43 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 10b3.d69a.93ab (bia 10b3.d69a.93ab)
Description: *** AP ***
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is on, output flow-control is unsupported
Last input never, output 00:00:01, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 6000 bits/sec, 3 packets/sec
1 packets input, 68 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
2361956 packets output, 395238328 bytes, 0 underruns
0 output errors, 0 collisions, 9 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
@ittechk4u1 wrote:
1 packets input
Look at the major discrepancy between the input vs output packet.  NOTHING is coming into the switch.
The AP is in u-boot (ROMMON).
Has anyone tried shut, wait for 10 seconds, no shut the port?
I tried 4-5 APs and all not coming UP at all.
If I connect these APs in another switch in same stack then its working.
What firmware is the switch running on?
16.12.1 (cat9k_lite_iosxe.16.12.01.SPA.bin)
