switch port to assign max power
arjun.suresh
we have switch Cisco switch WS-3850-48P-S with primary and secondary power unit(715WAC+715WAC).In this case we are require the particular port to assign max power 30 watts. Let you know above model switch to assign upto 30 watts is possible or not.
Leo Laohoo
Catalyst 3850 should be able to support up to 30w PoE.  The interface command is:
power inline auto max 30000
mohanak
power inline consumption default wattage
Example:
Switch(config)# power inline consumption default 5000
Configures the power consumption of powered devices connected to each the PoE port on the switch.
The range for each device is 4000 to 30000 mW (PoE+). The default is 30000 mW.
Note
When you use this command, we recommend you also enable power policing.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3850/software/release/3.2_0_se/multibook/configuration_guide/b_consolidated_config_guide_3850_chapter_011010.html#task_1875998
