System Name change post initial HA sync up
Muhammed Adnan
Level 7
Level 7
Hello Experts,
Having the prompt name of standby WLC changing in accordance with the prompt name of active WLC by suffixing it with "-standby" is understood.
However should not the "sysname" of the standby WLC retained even after HA sync up completes?
Scott Fella
In SSO, the configuration is shared by the primary, so the standby will inherit the sysname of the primary. Even if you break SSO, you will notice that the former standby still has the sysname of the primary it was associated in SSO.
-Scott
