T-Mobile/TMobile GSM with HWIC-3G-GSM Module
BRIAN SEKLECKI
All:
The Interwebs are completely berift of any discussion of anyone successfully using a USA T-Mobile SIM.
I got a few Cisco factory-recertified/reconditioned HWIC-3G-GSM's from Blackbox Resale Services (A big thanks to Charlie Wade @ Blackbox for the killer pricing) and gave it a whirl.
Turns out that T-Mobile's HSDPA/UMTS/EDGE/GPRS works perfectly.
For the sake of Google's index'ing on the topic, here's a working config:
br0#sh hard
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.0(1)M3, RELEASE SOFTWARE (fc2)
br0#sh run int cellular 0/0/0
Building configuration...
Current configuration : 354 bytes
interface Cellular0/0/0
description T-Mobile or DEATH-FAST
ip address negotiated
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer in-band
dialer idle-timeout 90 either
dialer string GSM
dialer-group 1
async mode interactive
ppp chap hostname FUXLRONHUBBARD
ppp chap password 7 03226E282D23136360212C2735333928
ppp ipcp dns request
end
br0#sh cellular 0/0/0 all
Hardware Information
Modem Firmware Version = H1_1_9_3MCAP C:/WS/
Modem Firmware built = 12/12/07
Hardware Version = 1.0
International Mobile Subscriber Identity (IMSI) = XXXXXXXXXX
International Mobile Equipment Identity (IMEI) = XXXXXXXXXX
Factory Serial Number (FSN) = XXXXXX
Modem Status = Online
Current Modem Temperature = 20 deg C, State = Normal
Profile Information
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = internet
Authentication = PAP
Username: FUXLRONHUBBARD, Password: FUXLRONHUBBARD
* - Default profile
Data Connection Information
Data Transmitted = 3191 bytes, Received = 4687 bytes
Profile 1, Packet Session Status = INACTIVE
        Inactivity Reason = Unknown
Profile 2, Packet Session Status = INACTIVE
        Inactivity Reason = Normal inactivate state
Network Information
Current Service Status = Normal, Service Error = None
Current Service = Combined
Packet Service = EDGE (Attached)
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = USA, Network = T-Mobile
Mobile Country Code (MCC) = 310
Mobile Network Code (MNC) = 26
Location Area Code (LAC) = 4001
Routing Area Code (RAC) = 10
Cell ID = 40172
Primary Scrambling Code = 0
PLMN Selection = Automatic
Registered PLMN = T-Mobile , Abbreviated =
Service Provider =
Radio Information
Current Band = GSM 1900, Channel Number = 649
Current RSSI = -50 dBm
Band Selected = Auto
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of Retries remaining = 3
000285: *Apr  2 19:32:09.615 UTC: %SEC-6-IPACCESSLOGNP: list 2 permitted 0 0.0.0.0 -> 207.46.197.32, 1 packet
000286: *Apr  2 19:32:09.615 UTC: Ce0/0/0 DDR: place call
000287: *Apr  2 19:32:09.615 UTC: Ce0/0/0 DDR: Dialing cause ip (s=0.0.0.0, d=207.46.197.32)
000288: *Apr  2 19:32:09.615 UTC: Ce0/0/0 DDR: Attempting to dial GSM
000289: *Apr  2 19:32:09.615 UTC: CHAT0/0/0: Attempting async line dialer script
000290: *Apr  2 19:32:09.615 UTC: CHAT0/0/0: Dialing using Modem script: GSM & System script: none
000291: *Apr  2 19:32:09.615 UTC: CHAT0/0/0: process started
000292: *Apr  2 19:32:09.615 UTC: CHAT0/0/0: Asserting DTR
000293: *Apr  2 19:32:09.615 UTC: CHAT0/0/0: Chat script GSM started
000294: *Apr  2 19:32:09.615 UTC: CHAT0/0/0: Sending string: ATDT*99#
000295: *Apr  2 19:32:09.615 UTC: CHAT0/0/0: Expecting string: CONNECT
000296: *Apr  2 19:32:09.659 UTC: CHAT0/0/0: Completed match for expect: CONNECT
000297: *Apr  2 19:32:09.659 UTC: CHAT0/0/0: Chat script GSM finished, status = Success
000298: *Apr  2 19:32:11.683 UTC: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to up
000299: *Apr  2 19:32:11.683 UTC: Ce0/0/0 DDR: Dialer statechange to up
000300: *Apr  2 19:32:11.683 UTC: Ce0/0/0 DDR: Dialer call has been placed
000301: *Apr  2 19:32:11.683 UTC: Ce0/0/0 PPP: Sending cstate UP notification
000302: *Apr  2 19:32:11.683 UTC: Ce0/0/0 PPP: Processing CstateUp message
000303: *Apr  2 19:32:11.683 UTC: PPP: Alloc Context [30B2733C]
000304: *Apr  2 19:32:11.683 UTC: ppp2 PPP: Phase is ESTABLISHING
000305: *Apr  2 19:32:11.683 UTC: Ce0/0/0 PPP: Using dialer call direction
000306: *Apr  2 19:32:11.683 UTC: Ce0/0/0 PPP: Treating connection as a callout
000307: *Apr  2 19:32:11.683 UTC: Ce0/0/0 PPP: Session handle[B7000002] Session id[2]
000308: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP: Event[OPEN] State[Initial to Starting]
000309: *Apr  2 19:32:11.687 UTC: Ce0/0/0 PPP: No remote authentication for call-out
000310: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP: O CONFREQ [Starting] id 1 len 20
000311: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP:    ACCM 0x000A0000 (0x0206000A0000)
000312: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP:    MagicNumber 0x8D4E2D31 (0x05068D4E2D31)
000313: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP:    PFC (0x0702)
000314: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP:    ACFC (0x0802)
000315: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP: Event[UP] State[Starting to REQsent]
000316: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP: I CONFREQ [REQsent] id 2 len 25
000317: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP:    ACCM 0x00000000 (0x020600000000)
000318: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP:    AuthProto CHAP (0x0305C22305)
000319: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP:    MagicNumber 0x86D67869 (0x050686D67869)
000320: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP:    PFC (0x0702)
000321: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP:    ACFC (0x0802)
000322: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP: O CONFACK [REQsent] id 2 len 25
000323: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP:    ACCM 0x00000000 (0x020600000000)
000324: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP:    AuthProto CHAP (0x0305C22305)
000325: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP:    MagicNumber 0x86D67869 (0x050686D67869)
000326: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP:    PFC (0x0702)
000327: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP:    ACFC (0x0802)
000328: *Apr  2 19:32:11.687 UTC: Ce0/0/0 LCP: Event[Receive ConfReq+] State[REQsent to ACKsent]
000329: *Apr  2 19:32:11.691 UTC: Ce0/0/0 LCP: I CONFACK [ACKsent] id 1 len 20
000330: *Apr  2 19:32:11.691 UTC: Ce0/0/0 LCP:    ACCM 0x000A0000 (0x0206000A0000)
000331: *Apr  2 19:32:11.691 UTC: Ce0/0/0 LCP:    MagicNumber 0x8D4E2D31 (0x05068D4E2D31)
000332: *Apr  2 19:32:11.691 UTC: Ce0/0/0 LCP:    PFC (0x0702)
000333: *Apr  2 19:32:11.691 UTC: Ce0/0/0 LCP:    ACFC (0x0802)
000334: *Apr  2 19:32:11.691 UTC: Ce0/0/0 LCP: Event[Receive ConfAck] State[ACKsent to Open]
000335: *Apr  2 19:32:11.691 UTC: Ce0/0/0 PPP: Queue CHAP code[1] id[1]
000336: *Apr  2 19:32:11.711 UTC: Ce0/0/0 PPP: Phase is AUTHENTICATING, by the peer
000337: *Apr  2 19:32:11.711 UTC: Ce0/0/0 CHAP: Redirect packet to Ce0/0/0
000338: *Apr  2 19:32:11.711 UTC: Ce0/0/0 CHAP: I CHALLENGE id 1 len 35 from "UMTS_CHAP_SRVR"
000339: *Apr  2 19:32:11.711 UTC: Ce0/0/0 LCP: State is Open
000340: *Apr  2 19:32:11.711 UTC: Ce0/0/0 CHAP: Using hostname from interface CHAP
000341: *Apr  2 19:32:11.711 UTC: Ce0/0/0 CHAP: Using password from interface CHAP
000342: *Apr  2 19:32:11.711 UTC: Ce0/0/0 CHAP: O RESPONSE id 1 len 36 from "FUXLRONHUBBARD"
000343: *Apr  2 19:32:11.711 UTC: Ce0/0/0 CHAP: I SUCCESS id 1 len 4
000344: *Apr  2 19:32:11.711 UTC: Ce0/0/0 PPP: Phase is FORWARDING, Attempting Forward
000345: *Apr  2 19:32:11.715 UTC: Ce0/0/0 PPP: Phase is ESTABLISHING, Finish LCP
000346: *Apr  2 19:32:11.715 UTC: Ce0/0/0 PPP: Phase is UP
000347: *Apr  2 19:32:11.715 UTC: Ce0/0/0 IPCP: Protocol configured, start CP. state[Initial]
000348: *Apr  2 19:32:11.715 UTC: Ce0/0/0 IPCP: Event[OPEN] State[Initial to Starting]
000349: *Apr  2 19:32:11.715 UTC: Ce0/0/0 IPCP: O CONFREQ [Starting] id 1 len 22
000350: *Apr  2 19:32:11.715 UTC: Ce0/0/0 IPCP:    Address 0.0.0.0 (0x030600000000)
000351: *Apr  2 19:32:11.715 UTC: Ce0/0/0 IPCP:    PrimaryDNS 0.0.0.0 (0x810600000000)
000352: *Apr  2 19:32:11.715 UTC: Ce0/0/0 IPCP:    SecondaryDNS 0.0.0.0 (0x830600000000)
000353: *Apr  2 19:32:11.715 UTC: Ce0/0/0 IPCP: Event[UP] State[Starting to REQsent]
000354: *Apr  2 19:32:12.719 UTC: Ce0/0/0 IPCP: I CONFNAK [REQsent] id 1 len 16
000355: *Apr  2 19:32:12.719 UTC: Ce0/0/0 IPCP:    PrimaryDNS 10.11.12.13 (0x81060A0B0C0D)
000356: *Apr  2 19:32:12.719 UTC: Ce0/0/0 IPCP:    SecondaryDNS 10.11.12.14 (0x83060A0B0C0E)
000357: *Apr  2 19:32:12.719 UTC: Ce0/0/0 IPCP: O CONFREQ [REQsent] id 2 len 22
000358: *Apr  2 19:32:12.719 UTC: Ce0/0/0 IPCP:    Address 0.0.0.0 (0x030600000000)
000359: *Apr  2 19:32:12.719 UTC: Ce0/0/0 IPCP:    PrimaryDNS 10.11.12.13 (0x81060A0B0C0D)
000360: *Apr  2 19:32:12.719 UTC: Ce0/0/0 IPCP:    SecondaryDNS 10.11.12.14 (0x83060A0B0C0E)
000361: *Apr  2 19:32:12.719 UTC: Ce0/0/0 IPCP: Event[Receive ConfNak/Rej] State[REQsent to REQsent]
000362: *Apr  2 19:32:12.823 UTC: Ce0/0/0 IPCP: I CONFREQ [REQsent] id 1 len 4
000363: *Apr  2 19:32:12.823 UTC: Ce0/0/0 IPCP AUTHOR: Done. Her address 0.0.0.0, we want 0.0.0.0
000364: *Apr  2 19:32:12.823 UTC: Ce0/0/0 IPCP: O CONFACK [REQsent] id 1 len 4
000365: *Apr  2 19:32:12.823 UTC: Ce0/0/0 IPCP: Event[Receive ConfReq+] State[REQsent to ACKsent]
000366: *Apr  2 19:32:12.823 UTC: Ce0/0/0 IPCP: I CONFNAK [ACKsent] id 2 len 22
000367: *Apr  2 19:32:12.823 UTC: Ce0/0/0 IPCP:    Address 26.20.132.231 (0x03061A1484E7)
000368: *Apr  2 19:32:12.823 UTC: Ce0/0/0 IPCP:    PrimaryDNS 10.177.0.34 (0x81060AB10022)
000369: *Apr  2 19:32:12.823 UTC: Ce0/0/0 IPCP:    SecondaryDNS 10.176.83.140 (0x83060AB0538C)
000370: *Apr  2 19:32:12.823 UTC: Ce0/0/0 IPCP: O CONFREQ [ACKsent] id 3 len 22
000371: *Apr  2 19:32:12.823 UTC: Ce0/0/0 IPCP:    Address 26.20.132.231 (0x03061A1484E7)
000372: *Apr  2 19:32:12.823 UTC: Ce0/0/0 IPCP:    PrimaryDNS 10.177.0.34 (0x81060AB10022)
000373: *Apr  2 19:32:12.823 UTC: Ce0/0/0 IPCP:    SecondaryDNS 10.176.83.140 (0x83060AB0538C)
000374: *Apr  2 19:32:12.823 UTC: Ce0/0/0 IPCP: Event[Receive ConfNak/Rej] State[ACKsent to ACKsent]
000375: *Apr  2 19:32:12.827 UTC: Ce0/0/0 IPCP: I CONFACK [ACKsent] id 3 len 22
000376: *Apr  2 19:32:12.827 UTC: Ce0/0/0 IPCP:    Address 26.20.132.231 (0x03061A1484E7)
000377: *Apr  2 19:32:12.827 UTC: Ce0/0/0 IPCP:    PrimaryDNS 10.177.0.34 (0x81060AB10022)
000378: *Apr  2 19:32:12.827 UTC: Ce0/0/0 IPCP:    SecondaryDNS 10.176.83.140 (0x83060AB0538C)
000379: *Apr  2 19:32:12.827 UTC: Ce0/0/0 IPCP: Event[Receive ConfAck] State[ACKsent to Open]
000380: *Apr  2 19:32:12.867 UTC: Ce0/0/0 IPCP: State is Open
000381: *Apr  2 19:32:12.867 UTC: Ce0/0/0 IPCP: Install negotiated IP interface address 26.20.132.231
000382: *Apr  2 19:32:12.867 UTC: Ce0/0/0 DDR: dialer protocol up
I wanted to get that posted before those clowns at AT&T buy up T-Mobile and ruin it for everyone.
~BAS
0 Replies 0
