Tacacs not working for 5508
yprasannas
Tacacs not working for 3 new 5508 WLC's...working fine for 6 old 4400 WLC's.
before 7.116 code upgrade...I remember 5508 was working on and off and now they are not.
Same configs on SW, WLC and ACS.
Debug on WLC gives..below message when Tacacs is attempted..
*aaaQueueReader: Oct 25 09:20:41.700: tplus_processAuthRequest: memory alloc failed for tplus
Any pointers for troubleshooting? Not sure why statistics show zero...?? Radius is working for users.
(wlc03) >show tacacs auth statistics
Authentication Servers:
Server Index..................................... 1
Server Address................................... 10.3.121.21
Msg Round Trip Time.............................. 0 (msec)
First Requests................................... 0
Retry Requests................................... 0
Accept Responses................................. 0
Reject Responses................................. 0
Error Responses.................................. 0
Restart Responses................................ 0
Follow Responses................................. 0
GetData Responses................................ 0
Encrypt no secret Responses...................... 0
Challenge Responses.............................. 0
Malformed Msgs................................... 0
Bad Authenticator Msgs........................... 0
Timeout Requests................................. 0
Unknowntype Msgs................................. 0
Other Drops...................................... 0
Server Index..................................... 2
--More-- or (q)uit
Server Address................................... 10.3.121.22
(wlc03) >show tacacs summary
Idx  Server Address    Port    State     Tout
1    10.3.121.21     49      Enabled   5
2    10.3.121.22      49      Enabled   5
Authorization Servers
1    10.3.121.21      49      Enabled   30
Accounting Servers
We can ping the TACACS servers...
7 Replies 7
Stephen Rodriguez
Looks like a memory issue  can you pull
show memory stat
show buffers
show process memory
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
>show memory statistics
System Memory Statistics:
Total System Memory............: 1028820992 bytes
Used System Memory.............: 458424320 bytes
Free System Memory.............: 570396672 bytes
Bytes allocated from RTOS......: 21939008 bytes
Chunks Free....................: 29 bytes
Number of mmapped regions......: 45
Total space in mmapped regions.: 212779008 bytes
Total allocated space..........: 12015112 bytes
Total non-inuse space..........: 9923896 bytes
Top-most releasable space......: 133800 bytes
Total allocated (incl mmap)....: 234718016 bytes
Total used (incl mmap).........: 224794120 bytes
Total free (incl mmap).........: 9923896 bytes
show buffers
Pool[00]: 16 byte chunks
    chunks in pool:    50000
    chunks in use:     19030
    bytes in use:      304480
    bytes requested:   90479 (214001 overhead bytes)
Pool[01]: 64 byte chunks
    chunks in pool:    40000
    chunks in use:     14519
    bytes in use:      929216
    bytes requested:   566395 (362821 overhead bytes)
Pool[02]: 128 byte chunks
    chunks in pool:    20000
    chunks in use:     7726
    bytes in use:      988928
    bytes requested:   672853 (316075 overhead bytes)
Pool[03]: 256 byte chunks
    chunks in use:     808
    bytes in use:      206848
    bytes requested:   154777 (52071 overhead bytes)
Pool[04]: 1024 byte chunks
--More-- or (q)uit
    chunks in pool:    15300
    chunks in use:     11645
    bytes in use:      11924480
    bytes requested:   4945714 (6978766 overhead bytes)
Pool[05]: 2048 byte chunks
    chunks in pool:    1000
    chunks in use:     189
    bytes in use:      387072
    bytes requested:   355272 (31800 overhead bytes)
Pool[06]: 4096 byte chunks
    chunks in use:     36
    bytes in use:      147456
    bytes requested:   102479 (44977 overhead bytes)
Raw Pool:
    chunks in use:     186
    bytes requested:   156052303
show process memory
Name               Priority       BytesInUse  BlocksInUse    Reaper
cslStoreManager    (240/  7)              0            0      (  0/  0)%
System Reset Task  (240/  7)              0            0      (  0/  0)%
reaperWatcher      (  3/ 96)              0            0      (  0/  0)%   I
osapiReaper        ( 10/ 94)              0            0      (  0/  0)%   I
TempStatus         (240/  7)            424            1      (  0/  0)%   I
pktDebugSocketTask (255/  1)              0            0      (  0/  0)%
LICENSE AGENT      (240/  7)           2228           85      (  0/  0)%   I
emWeb              (  7/ 95)        1235795        20743      (  0/  0)%   T 300
webJavaTask        (240/  7)              0            0      (  0/  0)%
fmcHsTask          (100/ 60)              0            0      (  0/  0)%
apstatEngineTask   (240/  7)              0            0      (  0/  0)%
rrcEngineTask      (240/  7)              0            0      (  0/  0)%
spectrumDataTask   (255/  1)        1614480           12      (  0/  0)%
spectrumNMSPTask   (255/  1)          28808            3      (  0/  0)%
wipsTask           (240/  7)              0            0      (  0/  0)%
tsmTask            (255/  1)              0            0      (  0/  0)%
cids-cl Task       (240/  7)              0            0      (  0/  0)%
ethoipSocketTask   (  7/ 95)              0            0      (  0/  0)%
ethoipOsapiMsgRcv  (240/  7)              0            0      (  0/  0)%
--More-- or (q)uit
envCtrollerStatus  (240/  7)              0            0      (  0/  0)%
rfidTask           (240/  7)              0            0      (  0/  0)%
idsTrackEventTask  (239/  8)              0            0      (  0/  0)%
DHCP Server        (240/  7)              0            0      (  0/  0)%
bcastReceiveTask   (240/  7)              0            0      (  0/  0)%
ProcessLoggingTask (240/  7)              0            0      (  0/  0)%
CDP Main           (240/  7)           3100           13      (  0/  0)%
sntpMainTask       (240/  7)              0            0      (  0/  0)%
sntpReceiveTask    (240/  7)              0            0      (  0/  0)%
cdpSocketTask      (240/  7)              0            0      (  0/  0)%
grouping Task      (255/  1)              0            0      (  0/  0)%
dot11a             (255/  1)             63            3      (  0/  0)%
rrm Socket Task    (  1/ 97)          35024            1      (  0/  0)%
rrm Socket Task    (255/  1)          35024            1      (  0/  0)%
dot11a             (255/  1)              0            0      (  0/  0)%
dot11b             (255/  1)            105            5      (  0/  0)%
dot11b             (255/  1)              0            0      (  0/  0)%
apfPmkCacheTimer   (240/  7)              0            0      (  0/  0)%
Apf Guest          (240/  7)              0            0      (  0/  0)%
RLDP Schedule Task (240/  7)              0            0      (  0/  0)%
--More-- or (q)uit
apfMsConnTask_5    (175/ 32)              0            0      (  0/  0)%
apfMsConnTask_4    (175/ 32)              0            0      (  0/  0)%
apfMsConnTask_6    (175/ 32)              0            0      (  0/  0)%
apfMsConnTask_7    (175/ 32)              0            0      (  0/  0)%
apfMsConnTask_3    (175/ 32)              0            0      (  0/  0)%
apfMsConnTask_2    (175/ 32)              0            0      (  0/  0)%
apfLbsTask         (240/  7)              0            0      (  0/  0)%
apfMsConnTask_0    (175/ 32)              0            0      (  0/  0)%
apfMsConnTask_1    (175/ 32)              0            0      (  0/  0)%
apfProbeThread     (200/ 22)              0            0      (  0/  0)%
apfOrphanSocketTas (240/  7)              0            0      (  0/  0)%
apfRogueDetectorTh (175/ 32)              0            0      (  0/  0)%
apfRogueTask       (240/  7)              0            0      (  0/  0)%
apfOpenDtlSocket   (175/ 32)              0            0      (  0/  0)%
apfRLDP            (175/ 32)            424            1      (  0/  0)%
apfRLDPRecv        (175/ 32)              0            0      (  0/  0)%
apfReceiveTask     (175/ 32)              0            0      (  0/  0)%
mmMfpTask          (175/ 32)              0            0      (  0/  0)%
mmMobility         (240/  7)           1272            3      (  0/  0)%
mmSSHPeerRegister  (240/  7)              0            0      (  0/  0)%
mmListen           (180/ 30)          99920          227      (  0/  0)%
tplusTransportThre (201/ 22)              0            0      (  0/  0)%
radiusCoASupportTr (201/ 22)              0            0      (  0/  0)%
--More-- or (q)uit
EAP Framework      (240/  7)              0            0      (  0/  0)%
aaaQueueReader     (225/ 13)           3518           12      (  0/  0)%
radiusRFC3576Trans (201/ 22)              0            0      (  0/  0)%
radiusTransportThr (201/ 22)              0            0      (  0/  0)%
pemReceiveTask     (240/  7)              0            0      (  0/  0)%
iappSocketTask     (240/  7)              0            0      (  0/  0)%
ccxRmTask          (230/ 11)              0            0      (  0/  0)%
ccxS69Task         (240/  7)            424            1      (  0/  0)%
ccxDiagTask        (240/  7)              0            0      (  0/  0)%
ccxL2RoamTask      (240/  7)         240424            3      (  0/  0)%
dot1xSocketTask    (240/  7)              0            0      (  0/  0)%
Dot1x_NW_MsgTask_7 (240/  7)              0            0      (  0/  0)%
Dot1x_NW_MsgTask_6 (240/  7)              0            0      (  0/  0)%
Dot1x_NW_MsgTask_2 (240/  7)              0            0      (  0/  0)%
Dot1x_NW_MsgTask_3 (240/  7)              0            0      (  0/  0)%
Dot1x_NW_MsgTask_4 (240/  7)              0            0      (  0/  0)%
Dot1x_NW_MsgTask_5 (240/  7)              0            0      (  0/  0)%
Dot1x_NW_MsgTask_1 (240/  7)              0            0      (  0/  0)%
Dot1x_NW_MsgTask_0 (240/  7)            424            1      (  0/  0)%
dot1xMsgTask       (240/  7)              0            0      (  0/  0)%
locpTxServerTask   (220/ 15)            408            2      (  0/  0)%
locpRxServerTask   (200/ 22)         428043         1961      (  0/  0)%
capwapSocketTask   ( 72/ 70)         303104          148      (  0/  0)%
--More-- or (q)uit
spamApTask6        (118/ 53)          25929           63      (  0/  0)%
spamApTask7        ( 53/ 78)          24233           59      (  0/  0)%
spamApTask5        (118/ 53)          23445           61      (  0/  0)%
spamApTask4        (118/ 53)          23513           58      (  0/  0)%
spamApTask3        (118/ 53)          19569           48      (  0/  0)%
spamApTask2        ( 53/ 78)          23809           58      (  0/  0)%
spamApTask1        ( 53/ 78)          22961           56      (  0/  0)%
spamApTask0        ( 78/ 68)          39189          106      (  0/  0)%
spamReceiveTask    (120/ 52)        2204024          252      (  0/  0)%
spamSocketTask     ( 32/ 85)              0            0      (  0/  0)%
Image License brok (240/  7)              0            0      (  0/  0)%   I
Image License brok (240/  7)             28            1      (  0/  0)%   I
IPC Main Thread    (240/  7)              0            0      (  0/  0)%   I
License Client Lib (240/  7)             96            1      (  0/  0)%   I
sshpmLscScepTask   (100/ 60)              0            0      (  0/  0)%
sshpmLscTask       (100/ 60)          25783         1739      (  0/  0)%
sshpmReceiveTask   (175/ 32)           6697           66      (  0/  0)%
sshpmMainTask      (100/ 60)         208440          358      (  0/  0)%
mfpKeyRefreshTask  (255/  1)              0            0      (  0/  0)%
mfpEventTask       (255/  1)              0            0      (  0/  0)%
mfpTrapForwardTask (255/  1)              0            0      (  0/  0)%
clientTroubleShoot (100/ 60)        2841248            4      (  0/  0)%
--More-- or (q)uit
loggerMainTask     (200/ 22)              0            0      (  0/  0)%
debugMainTask      (200/ 22)              0            0      (  0/  0)%
dot3ad_lac_task    (240/  7)          32901            3      (  0/  0)%
gccp_t             (240/  7)           5864            5      (  0/  0)%
dot1dTimer         (240/  7)              0            0      (  0/  0)%   T 300
dot1dRecv          (250/  3)              0            0      (  0/  0)%
uart_session       (240/  7)              0            0      (  0/  0)%
StatsTask          (240/  7)              0            0      (  0/  0)%
fdbTask            (240/  7)              0            0      (  0/  0)%
broffu_SocketRecei (100/ 60)             13            1      (  0/  0)%
SNMPProcMon        (240/  7)              0            0      (  0/  0)%   T 300
RMONTask           ( 71/ 71)              0            0      (  0/  0)%   I
SNMPTask           (240/  7)          61089         1064      (  0/  0)%
DHCP Socket Task   (240/  7)              0            0      (  0/  0)%
DHCP Proxy Task    (240/  7)              0            0      (  0/  0)%
dhcpClientTimerTas (240/  7)              0            0      (  0/  0)%
DHCP Client Task   (240/  7)              0            0      (  0/  0)%   T 600
BootP              (240/  7)              0            0      (  0/  0)%   T 300
TransferTask       (240/  7)            848            2      (  0/  0)%   I
osapiTimer         (100/ 60)          13024            2      (  0/  0)%   T 300
nim_t              (100/ 60)           2447            3      (  0/  0)%
dtlArpTask         (  7/ 95)          98436            3      (  0/  0)%
dtlTask            (100/ 60)          41089           20      (  0/  0)%
--More-- or (q)uit
dtlDataLowTask     (  7/ 95)              0            0      (  0/  0)%
sysapiprintf       (240/  7)          22657            3      (  0/  0)%
osapiBsnTimer      ( 95/ 62)              0            0      (  0/  0)%
fp_main_task       (240/  7)       153068796        26868      (  0/  0)%
can you also grab a
show run-config no-ap
HTH,
Steve
reboot fixed the tacacs....which is not good....
Other WLC's we redid the tacacs and they are also fine...FYI:- 7.116 code upgrade started Tacacs issue.
OMG -- I had to do this very same thing ... VERY ODD ...
Looks like this is classified as a bug..It says it will be fixed in 7.2 code??
CSCsg87862   WLC Console/Telnet/SSH/HTTP/HTTPS Hang When AAA server is unresponsive
This might be also impacting Radius....
I have been pulling my hair with Radius issues for over a year and Tacacs for several months. ACS reboot has been fixing Radius..weird..Many TAC cases have been opened.
It is time for a hair cut...no need to pull hair!
Got a confirmation that this bug does not affect Radius...will check with AAA team.
