Telxon PTC 960 connection problem
patriciog
Community Member
I have problems trying to connect an older Telxon PTC 960 that works fine with Access Point (Aironet old type), but can´t connect to Access Point Cisco 350.
The error is Network timeout.
The terminal connects OK to Lucent 802.11b compliant Acces Point.
Any suggestions are welcomed.
gverr
Level 2
Level 2
First of all what radio do you have inthe PTC 960SL?
Likely a 4x00 since you connect to a Lucent 802.11b AP.
If it is so, I would have a look in the radio settings of the 350, at the preamble size. For these legacy radio's, the AP needs to support "LONG" preamble.
Guy
Senior WLAN support specialist
