Temperature - 1400 Bridge
dyorke0403
We are having some servere temps in Upsate NY this week.  Temps ranging from -10 to -18. This morning my 1400 wireless bridge is reporting the rdaio has been disable due to a temp alarm. Does anyone know if the radio get re-enabled after the temp resumes to normal ranges. I found in the config guide that normal ranges are between -22 and 132 F. Thoughts are appreciated.
dyorke0403
FYI... Once Temp reached 4° radios re-enabled.
