Temporary loss of WIFi connection between handheld terminal and AP
DanielTelnet
We got new terminals Honeywell EDA61K, but we have a problem with connection loss.
Wireless LAN Controller is Aironet 2800 Series ME. Terminals randomly lose connection. After a while he returns.
I switched the WiFi network only to 2.4. This reduced the number of appearances. Logs in the attachment
Do you have any idea how to solve this problem?
Mark Elsen
 - You can only get more insights on that with full client debugging on the controller according to : https://www.cisco.com/c/en/us/support/docs/wireless/aironet-1200-series/100260-wlc-debug-client.html (corrected)
   you can have the resulting client debugs processed with  Wireless Config Analyzer
  - Make sure that the ME based controller software version is up to date
  - Checkout it's configuration using WirelessAnalyzer input (procedure) for AireOs controllers
     and have the output analyzed with Wireless Config Analyzer
  - Make sure that the Honeywell devices are on latest firmware (if applicable) , to avoid wifi driver bugs ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
What firmware is the controller running on?
If the AP gets rebooted, does the problem temporarily go away?
Rich R
Refer to TAC recommended link below for current recommended software version.  Depending on what subordinate APs you're using you should ideally be using 8.10.190.0 (check compatibility matrix if you have older APs).
