TFTPing WLC code with a Macbook Pro
Islam Sallaj
Level 2
Level 2
Has anyone had any success tftping wlc code using the wlc GUI tftp function with a Macbook Pro?  I am using TFTP 3.3.1 for mac and it doesn't seem like it wants to connect?  Is there a firewall setting or port that needs to be open on the Macbook end that i'm missing?  I can ping my macbook pro from the WLC gui with no issue.
Any thoughts?
izzy
Leo Laohoo
Go to Management > Mgt via Wireless
By default, the tick box is un-ticked.  Tick that and you'll be able to manage the WLC using wireless (not recommended though).
