the LED will glow solid orange
gtstech
Level 3
Level 3
CW9166D1 device has a phenomenon that the LED will light up orange continuously. And the boot status will be reset after 5 seconds.
Do I need to upgrade the device's OS?
Device log is below!!
I read this document and it says this: https://documentation.meraki.com/MR/MR_Installation_Guides/CW9166_Installation_Guide
Mark Elsen
  - I think the AP is broken and needs to be replaced (RMA)
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
@gtstech
  What exactly is the Orange LED behavior?
It is permanent orange, which suggest hard failure? or
• Blinking Orange - AP can't find uplink?
