TKIP MIC errors reported in EAPOL key msg from client
Augustgood
Level 5
Level 5
hi all,
my bar code reader motorola MC9190 can't connect to wifi net with wpa/wpa2-tkip psk. i receive the following error:
TKIP MIC errors reported in EAPOL key msg from client 40:83:de:89:0a:33
WPA_KEY_MIC_ERR: 1x_eapkey.c:618 TKIP MIC errors reported in EAPOL key msg from client xxxxxxxcxcc
if i connect the same client on autononous ap work perfectly, who can help me?
i verified the pre shared key,but the device can't connect.
Leo Laohoo
Use either WPA or WPA2.  Don't enable both and "expect" the wireless client(s) to choose because they won't/can't.
i solved the problrm, i found a mismatch on a pre share key.
