TPC power in High Density environment
acbenny
Dear Expert,
As I know, there is RRM to control the TPC power automatically to all AP controlled by WLC. Is there is any reason to create RF profile to set limit the power range in TPC setting under High Density environment?
Thank you!
 Yes, there is. The advantage of RF profile is allow you to change RF characteristics per area.
 The idea of RF profile is segment you network and permit you to create customized environment depending your needs.
-If I helped you somehow, please, rate it as useful.-
