06-25-2015 10:02 AM - edited 07-05-2021 03:28 AM
I will start off by saying, my network skills are very remediate... but I'm having an issue. I am wanting to configure 2 of my existing AP's for a new host name and IP. I am wanting to do this via Serial (which I have) and using PuTTY. When I initially connected, I went into enable, and tried typing in config t and it says invalid input. I went in and reset to factory. Now, I can go into enable but this message keeps popping up and it's very frustrating. Message is: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an IP !!
Now, these are my commands available:
Exec commands:
cd Change current directory
clear Reset functions
clock Manage the system clock
crypto Encryption related commands.
debug Debugging functions (see also 'undebug')
delete Delete a file
dir List files on a filesystem
disable Turn off privileged commands
enable Turn on privileged commands
exit Exit from the EXEC
fsck Fsck a filesystem
help Description of the interactive help system
led LED functions
lock Lock the terminal
login Log in as a particular user
logout Exit from the EXEC
lwapp lwapp exec commands
mkdir Create new directory
monitor Monitoring different system events
more Display the contents of a file
name-connection Name an existing network connection
no Disable debugging functions
ping Send echo messages
pwd Display current working directory
release Release a resource
reload Halt and perform a cold restart
rename Rename a file
renew Renew a resource
rmdir Remove existing directory
send Send a message to other tty lines
set Set system parameter (not config)
show Show running system information
systat Display information about terminal lines
terminal Set terminal line parameters
test Test subsystems, memory, and interfaces
traceroute Trace route to destination
undebug Disable debugging functions (see also 'debug')
upgrade Upgrade software
verify Verify a file
where List active connections
Not sure what the next step is, and how to get rid of that message. I do not want to connect to my WLC just yet, I just want to program via Serial since this will be on a different subnet IP than what is here, locally.
Solved! Go to Solution.
06-26-2015 12:08 AM
This is a CAPWAP AP and it can only be managed when you have Wirless LAN controller.
If you want to change hostmname and IP via serial interface then do these:
1. Run this command "debug capwap console cli"
2. Then start using config t and run your normal command to change both.
Don't forget to rate helpful posts
06-25-2015 03:18 PM
Please refer to the below link :
http://mrncciew.com/2013/03/17/ap-registration/
06-26-2015 12:08 AM
06-26-2015 04:11 AM
