Trouble with AP adder licences
Hello!
We use a Cisco WLC 5520 HA at our school. The controllers have no build-in licenses, but 115 AP Adder licenses. There are currently 115 AP's in operation. Today I added five more AP adder licenses via the GUI, then saved the configuration and rebooted the controller. Now the WLC shows only 51 of 115 AP's. What am I doing wrong and what do I have to change so that all 115 access points will be activated again?
Sandeep Choudhary
can you do force failover by using this command "redundancy force-switchover" on primary WLC and check secondary WLC ?
Dont forget to rate helpful posts
