Tshoot wireless Guest
papemamadou.sow
I have a problem with my controller 5760 for doing mobility anchor . The users get address with DHCP from the controller anchor a cisco 5508 but the authentication page (http:1.1.1.1/login.html )  doesn't display . The tunnel is up between the local controller and the anchor witch uses new mobility .
Controller anchor 5508 take authentication with ACS 5.2 . Can't you help me to solve the problem?
My local controller : 5760 software 3.2.2 My anchor controller : 5508  software 5.6 My ACS : 5.2
First are the softwares compatibility?
Pls post below output from your 5760
show wireless mobility summary
show wlan id  <wlan_id_for_guest> | be Mob
Rasika
*** Pls rate all useful responses *****
Prasan Venky
Level 3
Level 3
Are you using customized web auth bundle..?
If you click on preview whether it displays the web page..?
