Turn off LED light for 3802i AP in mobility express mode
dcnguyen
WLC controller based configuration allows for the ability to turn off the status LED on the WAPs.  After converting the setup to Mobility Express I cannot for the life of me see any way to do it in the GUI (browser) or the CLI.  Any undocumented commands I can run to turn off the LED like I can when the APs are managed by a WLC?
Sandeep Choudhary
Can you try this command on CLI:
config ap led-state { enable | disable} { cisco_ap | all}
Dont forget to rate helpful posts
Sandeep Choudhary
Thanks Sandeep, that worked.  The command needs to be issued on the mobility express controller.
