Turning APs' power on and off
james_90_
Is it possible to either power on and off lightweight PoE-connected APs from the central controller and/or explicitly tell the AP to go from high-power mode into low-power mode (with all radios turned off) and vice versa?
(Ideally I'd like to do this via CLI or some other kind of scripting).
Many thanks!
J
sschmidt
You can use an AP template from WCS to turn on and off the radios as well as adjust the power settings.  These are under the 802.11a/n and 802.11b/g/n tabs of the AP template.  These can also be scheduled.
http://www.cisco.com/en/US/docs/wireless/wcs/6.0/configuration/guide/6_0temp.html#wp1064409
Leo Laohoo
If you upgrade the IOS of your PoE switches to 12.2(50) or later you can avail of Cisco EnergyWise.  You can set time and date to turn your APs on or off.
Q&A:  Cisco EnergyWise Update
http://www.cisco.com/en/US/customer/prod/collateral/switches/ps5718/ps10195/qa_c67-557266.html
Cisco EnergyWise Configuration Guide
http://www.cisco.com/en/US/customer/docs/switches/lan/energywise/phase2/ios/configuration/guide/ew_v2.html
Don't forget to rate our posts.  Thanks.
